Working with an M-16iA and R-J3. What would prevent this controller from auto-configuration of the I/O? The appropriate variable is set to TRUE, but with every power cycle, if I delete all the assignments, the configuration lists digital inputs and digital outputs from 1-512 unassigned. Or, if I try to manually configure, it will maintain what I've entered after cycling power but say the configuration is invalid.
As a side note, it takes an abnormally long amount of time for the controller to create the I/O tables at startup... if I try to view the I/O menu too quickly, it says something to the effect of 'menus not created, try again.'
I feel like I've been through a similar situation once before, but cannot recall for the life of me what the issue was. And initial attempts at searching under the new format have been fruitless, so I apologize if this has been addressed here already (as I am sure it has been).
