I need to make an Ethernet cable for ftp file transfer. Does anyone know what the crossover connection is called or what coloured wire goes where
s4c+ ethernet cable crossover
- Sean_MMSNI
I am not sure but I bet google knows.
TIA 586A on one end TIA 586B on the other end.
Yes this works, Thank you.
With modern PC or Laptop most time you can use a normal patch wire 1:1. The modern interfaces have auto negotiation and switch the pins on the mainboard automatically.
I must try this, I was told the cable had to be a special crossover one so never even tried a normal one.
I've always used a crossover cable to connect w/ the service port on the front... but then, laptop is similar vintage as/to the S4C+ machines. The LAN port usually connects to hub/switch, so it is usually a straight cable.
Same as Iowan for S4C+ & IRC5.
When traveling, I carry a quality OEM cable with snagless ends and an RJ45 M/F crossover adapter instead of separate straight & crossover cables.
Same as Iowan for S4C+ & IRC5.When traveling, I carry a quality OEM cable with snagless ends and an RJ45 M/F crossover adapter instead of separate straight & crossover cables.
Where did you purchase these, was it from ABB?
Not ABB. Search "RJ45 M/F Crossover" on the internet. Don't remember where we bought them but there are lots of options. We bought 10 and I handed most of them out to others at work.
