I wanted to check what options my robot has, so I tried to do backup
I've inserted my USB to teach pendant, then I pressed Menu>File>File>F4[BACKUP]
But there is an information "Device is protected", what should I do???
Backup problem
Janusz111 -
December 2, 2018 at 3:25 PM -
In the file menu press F5 and select device, then select UT1
Thank you for your answer. Do you know where can I find a file with described options numbers? I want to know if I had option to make connection via EthernetIP, Profibus, or Profinet, and check what options we had on the robot.
Hello
Look the ORDERFIL.DAT
Bye
If you have to do multiple robots (I did like 74 robots one night) I found that putting the USB drive into the slot on the robot cabinet works the fastest. It took under a minute per robot vs the 5-10 minutes it would take using the TP USB slot. If you choose to use the USB on the Robot cabinet select UD1 and then backup.
