Problem with points after a collision or after a period of time
  • ocj
  • November 27, 2018 at 5:37 PM
  • ocj
    Hello, I am having some problem with the fanuc robots and I do not understand what is due, if someone can help me please.
    The problem is that after a while in operation of the robot or after a collision loses the points but only certain areas and when performing the corresponding offset this is no longer in the correct picking position, what can it be?
  • stare284
    24
    373
    • November 27, 2018 at 6:02 PM
    What model robot and controller?
    Which axis is off?
    Is this a line tracking system? Vision? Basic pick and place?
  • ocj
    • November 27, 2018 at 8:54 PM
    It is a LR Mate 200iD and the controller is a R-30iB Mate
    It happened to me in two cases when taking pieces of a bed, where I was working correctly and after a collision the point of catching deviated a couple of millimeters on the Y axis, when picking the piece touched the fingers with it.
    And the other situation is to remove parts of a mandrino, where to go to the point with a certain offset the piece did not finish catching it by its point of catch and the cog above, in this second case the robot had been working for 2 years and in a principle has not suffered a collision, on the other hand the points where it places the pieces, similar to the one of catching, continued working correctly.
    Thanks for your help
  • jrv5207
    94
    • November 27, 2018 at 9:17 PM
    I have experienced the situation when the EOAT was not pinned. So it shifted after a collision. Also one of the bolts were bent causing the fingers of the EOAT to not be straight.
  • Racermike123
    13
    901
    • November 28, 2018 at 12:05 AM
    LR Mates have harmonic drives which are fragile.
    A seemingly insignificant collision can damage the drive causing the problems you are experiencing.
    Jog each axis through it's full range and look for bouncing. If it does you will need to tear it down for inspection.
