How to make a good PNS ?!?!
  • d.kerekes
  • November 23, 2018 at 3:55 PM
  • d.kerekes
    16
    Hello Guys!
    I tried to make a "main" program, but I had an issue. In the first level , I want to choose the type of product, second level what to do with the product ( this is necessary, because, if the robot stops meanwhile the production , in this case we should start the robot from the middle of his cycle ) .
    In the third level will be the programs, whit the movements .
    If the robot finished his third level program, the program jump back to the second level, is it possible, to jump form the third level to the first one ?
    Thanks for the answers !!!
    Level1:
    IF DO[125:ON ]=ON,JMP LBL[1] ;
    3: UALM[1] ;
    4: ABORT ;
    5: LBL[1] ;
    6: WAIT DI[125:OFF]=ON ;
    7: R[150]=GI[50:0] ;
    8: ;
    9: SELECT R[150]=1,CALL P1 ;
    10: =2,CALL P2 ;
    11: =3,CALL P3 ;
    12: ELSE,CALL ABORT ;
    13: JMP LBL[1] ;
    Level2: Actually this is the Program "P1"
    1:
    2:
    3: R[151]=GI[51:0] ;
    4: ;
    5: IF (R[151]=1)) THEN ;
    6: CALL P1_1 ;
    7: ELSE ;
    8: ENDIF ;
    9: ;
    10: IF (R[151]=2)) THEN ;
    11: CALL P1_2 ;
    12: ELSE ;
    13: ENDIF ;
    Level3: Actually this is the Program "P1_1"
    1:J P[HOME2] 100% CNT100 ;
    2:UTOOL_NUM= ;
    3:UFRAME_NUM= ;
    4:WAIT DI[102:AREA_ST02]=ON ;
    5:DO[102:AREA_ST02]=ON ;
    6:CALL GRP1_CLOSE ;
    7:J P[1] 100% CNT100 ;
    8:J P[2] 100% CNT100 ;
    9:J P[3] 100% CNT100 ;
    !FRAME DROP POSITION IN ST02 POS1 ;
    10:L PR[4:DROP_FR_ST2_P1] 500mm/sec FINE ;
    11:CALL GRP1_OPEN ;
    !DRIVE UP IN "Z" AFTER DROP POSITION ;
    12:PR[X]=LPOS ;
    13:PR[X,3]=PR[X,3]+80 ;
    14:L PR[X] 500mm/sec CNT100 ;
    15:J P[5] 100% CNT100 ;
    16:J P[6] 100% CNT100 ;
    17:J P[HOME1] 100% CNT100 ;
    18:DO[102:AREA_ST01]=OFF ;
    /END
  • Fabian Munoz
    133
    Articles
    1,517
    • November 23, 2018 at 6:14 PM
    HI
    At the end of
    R[1]=3 Use a register and just put any value
    then on
    1:
    2:
    4: ;
    6: CALL P1_1 ;
    if r[1] = 3 jump label 99
    7: ELSE ;
    8: ENDIF ;
    9: ;
    11: CALL P1_2 ;
    12: ELSE ;
    13: ENDIF ;
    label 99
    /END
    basically you just go through p1,, do something similar for p2
    Retired but still helping
