Get the P out of MOVJ
  • I have what I feel is probably a pretty stupid question...
    I am transcribing some programs from an old XRC robot into a new(er) NX100 robot. The line I am trying to transcribe is this:
    MOVJ VJ=10.00 PL=1
    When I pull up the MOVJ command in the Inform List on the NX100, it inserts this into the buffer line:
    MOVJ P000 VJ=50.00
    There is no option in detail edit to remove the P variable, and I don't need (or want) a position variable for this movement.
    Lest I look like a complete idiot, I know the original line is a joint move, velocity of 10, position level 1 (tight to target). The position is hard-coded into the program and can be changed by highlighting and modify-enter.
    But how the heck to I get rid of that P variable?
  • Hei
    I have not worked with the NX, but on a DX there's a MOVx instruction in the buffer line when you have the Inform List closed. Using that MOVx instruction you get the position hard-coded into the JOB. The MOVx instructions in the Inform List all use position variables.
    Hope it helps
