Fanuc - PLC communication
  • CrazyRobo
  • November 16, 2018 at 10:38 AM
  • CrazyRobo
    Guest
    Hi guys,
    I'm an amatour in robots programming, because I don't have many chances to work with it at my university, but:
    We have a fanuc robot, and Siemens PLC with HMI panel, and I was wondering if it is possible to controll robot moves from HMI panel buttons and send informations about current position from robot to PLC. We don't have any software for the robot like roboguide so I can only use teach pendant.
    If you know if it is possible, and know how to solve this I would be grateful for your help.
    :help:
  • dewitm
    99
    • November 16, 2018 at 12:12 PM
    'control robot moves' can mean a lot of things, do you mean:
    1. Jogging the robot
    2. Select a predefined position and move the robot to that position
    3. Use calculations based on inserted values on hmi and move to the calculated position...
  • bidzej
    23
    592
    • November 16, 2018 at 1:27 PM
    You want to jog ther robot from the PLC/HMI?
    If so, write a couple of macros for each axis and direction and use DIs to call these macros.
    For example, a macro for moving J1 in + could look like this:
    PR[1] = JPOS
    PR[1,1] = PR[1,1] + 1
    J PR[1] 100% CNT100
    Then, in Macro Setup, assign a DI to this macro. Assuming that all conditions for running a motion macro are satisfied, the macro will be executed as long as the DI is ON, which will result in jogging the robot by 1 deg. with each iteration.
    Repeat this for all axes and directions, possibly both for joint and linear motion (which will differ by JPOS/LPOS and motion type).
  • CrazyRobo
    Guest
    • November 16, 2018 at 1:47 PM
    Sorry for not specifying the movement.
    I would like to create 12 buttons on my HMI similar to these on teach pendant and use it in the same way as on TP World mode and show the current position on HMI.
  • bidzej
    23
    592
    • November 16, 2018 at 1:49 PM
    So you have your answer above. Be aware, that these motion macros will only be executed in AUTO, with the TP switched OFF, safety IO etc.
  • CrazyRobo
    Guest
    • November 18, 2018 at 1:21 AM
    Ok, thanks for your help guys, but there is a little problem.
    Firstly, can I show the current position on the HMI panel, and if yes - how can I do this?
    We have only 6 DI available so if I understand you correctly I'm able to do movement only in 3 axes, so - is there any other way to achieve this movement control with only 6 DI?
  • Sergei Troizky
    67
    650
    • November 19, 2018 at 10:47 PM
    What communication protocol(s) does your robot support now?
    Is there anything listed below Flag in the I/O menu?
    What HMI?
  • CrazyRobo
    Guest
    • November 19, 2018 at 11:20 PM
    In the I/O menu we have range 109-120 DI and DO assigned to rack 34 so as I guess - they are flags
    Except that we have also 81-88 DI/DO assigned to rack 48 - address mapped I/O for LR Mate Peripheral connectors
    HMI panel - Simatic TP700 comfort
  • Sergei Troizky
    67
    650
    • November 20, 2018 at 12:10 AM
    I did not ask about assignments.
    Is anything listed after Flag in I/O menu, after pressing F1-TYPE?
