DELETE a FILE in MD: using KAREL(FILE NAME TOBE EXTRACTED FROM DATA STRINGS REGI
  • balajitdm2000
  • November 9, 2018 at 2:03 AM
  • balajitdm2000
    Guest
    I'm Newbie to KAREL WORLD, Could somebody help me with the karel code to--
    Deleting a FILE in MD: using KAREL.pc program(FILE NAME TOBE EXTRACTED FROM DATA STRINGS REGISTERS)
    As a first step I am trying to create a .KL FILE in ROBOGUIDE9.0 to just delete a file using file name as below, I'm missing something need help to debug or correct code
    PROGRAM DELPRGLB
    VAR
    status : INTEGER -- The status returned from the built-in calls
    file_spec : STRING[30] -- The created file specification for DELETE
    BEGIN
    DELETE_FILE (MD:\BALA.TP, FALSE, status) -- Delete the file.
    IF (status <> SUCCESS) AND (status <> 10003) AND
    (status <> 85014) THEN
    WRITE (’ERROR ’, status,’ IN attempt TO delete ’,CR, file_spec,CR)
    ENDIF
    END DELPRGLB
    Edited once, last by balajitdm2000 (November 9, 2018 at 2:09 AM).
  • andreic
    24
    280
    • November 9, 2018 at 7:07 AM
    I've adjusted the code a little:
    PROGRAM DELPRGLB
    VAR
    STATUS : INTEGER -- The status returned from the built-in calls
    BEGIN
    DELETE_FILE ('MD:\BALA.TP', FALSE, STATUS) -- Delete the file.
    IF (STATUS <> 10003) AND (STATUS <> 85014) THEN
    WRITE ('ERROR', STATUS,'IN attempt TO delete',CR, file_spec,CR)
    ENDIF
    END DELPRGLB
    I have some remarks:
    1. Always format your code in order to look easier to read.
    2. You have to enclose MD:\BALA.TP in ' '.
    3. You must enclose ’ERROR ’ .. in ' ', not in ’ ’.
    4. Variable SUCCESS is not declared.
  • balajitdm2000
    Guest
    • November 13, 2018 at 1:02 AM
    Awesome, Thank you very much Mr. Andreic, it worked.
    As I said as next step I want to choose\take the .TP file name for deletion from the char_array send from PLC.
    So I am thinking if I can modify the karel.pc with a dynamic String registers SR[1} (instead of a single definite file name) like the way I call in TP programs for program execution
    some thing like the attached Pictures
    Any Help :help:
    Images
      • 6.19 kB
      • 390 × 69
      • 13
      • 20.05 kB
      • 577 × 330
      • 20
    Files
    SR.PNG_thumb 6.04 kB – 170 Downloads pgmcall.PNG_thumb 16.36 kB – 168 Downloads
    Edited once, last by balajitdm2000 (November 13, 2018 at 1:03 AM).
  • andreic
    24
    280
    • November 13, 2018 at 1:26 PM
    Depending on your controller type you can use GET_STR_REG for getting string into a variable from SR[].
    You can set back the value in SR[] using SET_STR_REG.
  • balajitdm2000
    Guest
    • November 15, 2018 at 8:38 AM
    Hi Andreic,
    Going back to our previous conversion on deleting programs, the karel P-code got generated and I was able to execute the pc program and the intended program got deleted successfully, and the program is no longer seen in Teach pendant.
    But I get an error " uninitialized data type used'. as attached in picture
    Is this because the file is deleted and our karel is still trying to return a status of ,' I am not sure.
    Images
      • 59.39 kB
      • 794 × 484
      • 22
    Files
    delerror.PNG_thumb 11.4 kB – 163 Downloads
  • andreic
    24
    280
    • November 15, 2018 at 1:50 PM
    file_spec is uninitialized.
    In this case you can see in your program. But you also can check by pressing ENTER on KAREL prog and selectes DATA -> Karel Vars.
    You must set file_spec to whatever you want, I guess the path of your file, so:
    Add file_spec='MD:\BALA.TP' replace DELETE_FILE (MD:\BALA.TP, FALSE, status) with DELETE_FILE (file_spec, FALSE, status).
