Hello.
Is there an option to program a shape that has a increasing or decreasing geometry?
For instance, a cirkel with a declining size, resulting in a spiral.
Hello.
The general equation of the logarithmic spiral is r = aeθ cot b, in which r is the radius of each turn of the spiral, a and b are constants that depend on the particular spiral, θ is the angle of rotation as the curve spirals, and e is the base of the natural logarithm.
First question, Do you have Math package ?
Thank you for your reply.
No i do not have a math package sir.
I did however solve the problem!
Would you mind sharing your solution? Just curious
Created position registers for 4 directions -y +y -x +x.
Hi FD
Can you explain the math you used for the spiral.
I programmed 1 circle with circular arc points. Then i looped the program using jump lbl.
Then add offset to each position register in every direction. Every loop you pass the position register offset. Set it to a certain value.
So you can let the circel spiral outward or inward.
Voila!
