Hi everyone,
I would like to set cartesian velocities for the smartServo instead of positions, but I didn't find anything in the API, does someone have experience with that?
Thank you in advance,
Lukas
Cartesian velocity control
lookahs -
October 26, 2018 at 4:38 PM -
I don't know what smartservo is but there is an option called enhanced velocity controller that accomplishes what you are looking for.
SmartServo is an additional module to the RoboticsAPI that allows to do closed-loop cartesian position control.
Where did you find this option "enhanced velocity controller"? I couldn't find it neither in the API nor in the documentation. Would it support closed-loop control (i.e. sending continuously cartesian velocity updates without invoking the breaks of the robot)? -
The 'Operating and Programming Instructions for System Integrators' of the SunriseWorkbench 1.14 contains an entire chapter (17) about the 'KUKA Sunrise.EnhancedVelocityController'.
Probably only available in v1.14 and up.
Not sure if you can use both SmartServo and EVC in parallel.
