I need help regarding Roboguide simulation. I can move robot automaticly according the robot program. I want to move automaticly conveyor and other movable devices. by the way, I am using tiral software. How can I do it.
Thanks in advance.
Thanks in advance.
I'm not much help.... but i've tried to do something simular on my system.
i first made a backup of robot. and loaded it into Roboguide. this however will not load anything extra graphics wise, for any Aux axis it might have. Our robots have a
spinning table with a infinite rotation.
when using roboguide i'm able to see the main robot in action, or if i'm stepping down the program i can see its movements, however if/when i does a move on the aux axis,
there is no graphics displayed, and none loaded for the table. However, it does function in Roboguide, i just can not see it via graphics. Just like on the Main robot teach pendant,
if i select Group 1 (is main robot) Group 2 (is Aux Axis (my table)). I can Jog my table by changing from Group 1 to Group 2 in roboguide and using J1 x-plus or x-minus. So unless you have the graphics attached / loaded into Roboguide you may have same problem i've got. It will move by changing group number, but you may not see it moving.
Paul........ p.s. i've only used the trial version also, don't think that has anything to do with it tho!!!!!
I can do simulation with the Machine > link depend on a DO. but it is moved only Z axis. I want to move X,Y,Z. how can I do it ?
Are you trying to move in all directions simultaneously? If it is only one direction you can uncouple the cad and change the axis origin. POint the Z in direction you want it to move.
is it possible to move all direction ? If possible please explain with detailed.
