Hi.
Details of my RobotStudio:
RobotStudio 6.07.01 SP1 (64-bit)
Version 6.07.7985.1011
I would like to install an add-in called CoordinateFile Import into the RobotStudio to import .csv file which has XYZ coordinates, but I don't know whether my procedure is correct, so I need guidance.
My procedure:
1. Copy the CoordinateFile Import file into this directory: C:\Program Files (x86)\Common Files\ABB Industrial IT\Robotics IT\RobotStudio\Addins
However, it couldn't work.
2. Copy the CoordinateFile Import file into this directory: C:\Program Files (x86)\ABB Industrial IT\Robotics IT\RobotStudio 6.07\Bin\Addins
However, it couldn't work too.
I downloaded the add-in file from: http://developercenter.robotstudio.com/blobproxy/devc…f413d16f450.htm
Please help Thank you.
