Hi!
I am trying to set up a BIS0,5/5000 Fanuc servo motor as a Continuous turn rotary motor. I want to use it as a spindle and I want it to rotate at 3000 rpm.
No matter how I set things up I cant make it work. I have tried setting it up as a Rotary axis rotating with a maximum speed of 18000 deg/sec. But i only rotates at maybe 50-100 rpm at 100%. A Fanuc technician set the system up a long time ago and when I check the backup files in RoboGuide he set it up like a linear axis. It rotates much faster but after a couple of turns it switches direction swiftly and then switches the direction again.
I am so confused. So, is there a continuous turn expert here who can help me? Do I have to change things in the system parameters as well or is it enough with editing the motor data in controlled start?
Cheers/ Runis86
