Any know how to calibrate a motoman nx teach pendant?
Motoman nx teach pendant
Beavissp82 -
October 8, 2018 at 5:10 PM -
Thread is Resolved
Re calibration Touch Screen NX100
Press 9 + Select + Interlock during power up.
Tap Ok when screen pops up.
Touch the bottom left hand side of the screen to get the start button to appear.
Tap the start button
Select settings
Select control panel
Select stylus icon
Tap the calibration tab.
Tap the re calibration button.
Press and hold (as accurate as you can) on the center of the cross hairs until it moves to the next position.
Press the enter button on the Pendant to exit.
Tap the OK button on the screen.
Cycle power -
Does anyone happen to know why I keep getting "START WAS CANCELLED" popping up on my Teach Pendant while Booting up with 9 + Select +Interlock pressed?? I've tried with 2 different pendants, same result every time. The cancelled screen pops up shortly after power to pendant with only one option to select which is OK. This just leave my screen blank indefinitely.
Select settings
Select stylus icon
Cycle powerDoes anyone happen to know why I keep getting "START WAS CANCELLED" popping up on my Teach Pendant while Booting up with 9 + Select +Interlock pressed?? I've tried with 2 different pendants, same result every time. The cancelled screen pops up shortly after power to pendant with only one option to select which is OK. This just leave my screen blank indefinitely.
You should get the "START WAS CANCELLED" box. You have gotten to step 2.
1. Press 9 + Select + Interlock during power up.
2. Tap Ok when screen pops up.
Continue on with the rest of Robodoc's calibration process. Touch the bottom left hand side of the screen to get the start button to appear.
Thanx for the response. I must be missing something. After I select the OK button shown in attachment, the screen is blank and when I go to tap the bottom LH portion of blank screen for Start Button to appear as Robo Doc mentions, I am getting nothing. I hear the beeping of pendant recognizing me touching the screen but nothing more.
It’s a pain in the butt but keep pressing in the lower left. Use something like a stylus or the edge of a credit card.
