Error panasonic G3-TM1400
  • You may turn off power then open the controller cabinet, then you could see the "release over run switch" on the right side on I/O board. You have to switch it to down then turn on power again.
    Next,you have to move all axis to release the current position until the message shown "please turn off and turn on power again" on pendant. Turn off the controller and switch the release over run switch to up position. Then power on again. Hope you can fix the problem.
