help with robot master program - speed not changes in kuka robot
  • Andrew149
  • September 26, 2018 at 12:20 PM
  • Andrew149
    35
    hi all,
    i am doing program for thermal spray coating.
    when robot master generated programs its having 10000s points in it.
    i am trying to change the speed of robot by setting the velocity as
    $VEL.CP=3
    but this dosent affect the actual speed of robot.
    please remember the programs generated has 10000s of point.
    i have attached a sample program.
    i dont understand why the robot speed is very slow?
    help
    Files
    PELTON_GE2M.src 535.55 kB – 23 Downloads
    All is well
  • Fubini
    283
    1,904
    • September 26, 2018 at 1:21 PM
    https://www.robot-forum.com/robotforum/kuk…2907/#msg102907
    https://www.robot-forum.com/robotforum/kuk…72079/#msg72079
    Read about C_VEL.
    Fubini
    Edited once, last by Fubini (September 26, 2018 at 1:26 PM).
  • Andrew149
    35
    • September 26, 2018 at 1:26 PM
    thanks fubini.. i will read and check
    All is well
  • Andrew149
    35
    • September 26, 2018 at 1:33 PM
    Fubini you mean to say change from LIN to Spline so that this limitation wont happen?
    All is well
  • Fubini
    283
    1,904
    • September 26, 2018 at 1:39 PM
    What i am trying to say is the following:
    If you stick to old motion you should use C_VEL. But also consider switching to spline blocks (switch to single command splines still has the same limitations.
    Fubini
  • Andrew149
    35
    • September 26, 2018 at 1:48 PM
    thanks fubini, i really appreciate your help on this.
    i am a robot simulator and new to kuka robot.
    i like to understand that my program will look like below line when we generate OLP from Robot master software, which is
    LIN {X -64.2835,Y 205.7571,Z -41.6742,A 2.4476,B 3.1076,C -103.5577} C_DIS
    you mean to say change C_DIS to C_VEL so my new line of code will look like
    LIN {X -64.2835,Y 205.7571,Z -41.6742,A 2.4476,B 3.1076,C -103.5577} C_VEL
    and also define C_VEL variable?
    is it right ?
    All is well
  • Andrew149
    35
    • September 26, 2018 at 2:30 PM
    fubini C_VEL dsent affect the speed :wallbash:
    i think only spline option i should try
    All is well
  • panic mode
    1,296
    13,137
    • September 26, 2018 at 3:03 PM
    if you want to use C_VEL, you also need to initialize corresponding element in $APO.
  • Andrew149
    35
    • September 26, 2018 at 5:28 PM
    panic i changed the $APO variable still its having speed issue.
    can you please tell me how spline works. does spline will have constant velocity which we are setting?
    All is well
  • Fubini
    283
    1,904
    • September 26, 2018 at 5:59 PM
    Read documentation on spline and your question is already answered in the links I have posted earlier.
    Fubini
  • Andrew149
    35
    • September 27, 2018 at 8:06 AM
    • #11
    Hi Fubini,
    i have read the documents and understand how spline works.
    now i write a code from robot master software as
    SLIN {X -88.5393,Y 99.1345,Z -30.0781,A -2.6482,B -17.6097,C -163.0256}
    but it throws some error in real robot, but what is the error the robot is not showing in teach pendant.
    any help?
    All is well
  • panic mode
    1,296
    13,137
    • September 27, 2018 at 2:05 PM
    • #12
    Quote from Bala
    [size=2]
    [/size]
    [size=2]i would recommend training/reading even though some swear by dowsing wand  :fish: [/size]
    [size=2]how exactly do you know that there is an error if it is not displayed?[/size]
  • Andrew149
    35
    • September 27, 2018 at 2:12 PM
    • #13
    Hi.. i have reduced total no og points now iam getting higher speed
    All is well
  • Fubini
    283
    1,904
    • September 27, 2018 at 2:56 PM
    • #14
    Quote
    As already suggested skyefire within
    Quote
    No. you did not understand spline, because we talked of spline blocks
    Quote
    is not a spline block.
    Please consider at least basic training.
    Fubini
    Edited once, last by Fubini (September 27, 2018 at 3:04 PM).
  • Andrew149
    35
    • September 28, 2018 at 10:24 AM
    • #15
    fubini hope below is the spline block
    SPLINE
    SPL XP1
    SPL XP2
    SPL XP3
    ENDSPLINE
    in basic training they not given any training regarding splines. i attended basic training.
    i am a robot OLP person and i have to give OLP generated to Robot programmer who is a kuka expert.
    i have to generate correct Syntax OLP because there is some syntax error in my input.
    thank you
    bala
    All is well
  • Andrew149
    35
    • October 1, 2018 at 11:23 AM
    • #16
    can someone please explain is the spine option nt available in krc2 v5.2?
    All is well
  • panic mode
    1,296
    13,137
    • October 1, 2018 at 11:33 AM
    • #17
    [size=2]Correct.... This is a perfect example why members are asked over and over to provide details when asking questions. see READ FIRST.[/size]
  • Andrew149
    35
    • October 1, 2018 at 11:36 AM
    • #18
    :waffen100: :waffen100::wallbash: :wallbash:
    i might read it first
    All is well
