Hi guys,
I have a station that uses 4 g3 Epson. These 4robots are controlled by two RC700,in other words its two robots per controller.
Each robot have in the tool a dispense system, and we are controlling the dispensing with a timer in a parallel process to the movement, this means that the pump is working during X seconds at a fixed rpm during the movement between 2 points.
I'm detecting an irregular dispensing and that make me wonder if the timer is reliable for this end. I'm dispensing a volume between 50 ul +-1%.
Because of this concern we are thinking to change the dispensing time to station's plc, but this requires a lot of effort to the team.
So what do you think? Could the robot timer be unreliable?
Looking forward for your opinion.
