  4. ABB Robot Forum
How to use GO or AO as a variable in rapid?
  • AndreaLu
  • September 19, 2018 at 3:15 PM
  • AndreaLu
    24
    Hello everyone
    I have a question...
    How to use GroupDigital as a variable in rapid program?
    this is my code,is it correct?
    MODULE MainModuleaaa
    VAR speeddata Work:= [100,20,5000,1000];
    PERS tooldata tPen :=[True,[[0,0,192],[1,0,0,0]],[0.001,[0,0,0.1],[1,0,0,0],0,0,0]];
    PERS wobjdata wobj10 := [FALSE, TRUE, "", [[0, 400, 0],[1, 0, 0, 0]],
                            [[0, 0, 0],[1, 0, 0, 0]]];
    PROC Main()
    ConfL \Off;
    ConfJ \Off;
    MoveL [[800,-400,[b]GO1[/b]],[0,0,1,0],[0,-1,-1,0],[9E9,9E9,9E9,9E9,9E9,9E9]],Work,z10,tPen\WObj:=wobj10;
    ENDPROC
    ENDMODULE
    the GO1 is GroupOutput,MoveL [[800,-400,GO1]....is it correct?if no correct ,how can I use GO or AO as variable for target?
    Thankyou for help!
    //=============Second day after 1st post ===========================
    i try this code:
    MODULE MainModule
    PERS tooldata tPen :=[TRUE,[[535.000,0.000,120.000],[0.707107,0.000000,0.707107,0.000000]],[0.1,[0,0,10],[1,0,0,0],0,0,0]];
    PERS wobjdata WObj6 := [FALSE, TRUE, "" , [[0, 0, 0],[1, 0, 0, 0]],[[0, 0, 0],[1, 0, 0, 0]]];
    VAR num xPosition;
    xPosition := DNGO1;
    VAR robtarget p1:=[[xPosition,-360.638,809.490],[-0.035,0.000,0.999,0.000],[0,-1,-1,0],[0,9E9,9E9,9E9,9E9,9E9]];
    PROC Main()
    ConfL \Off;
    ConfJ \Off;
    MoveL p1,Work,z10,tPen\WObj:=WObj6;
    ENDPROC
    ENDMODULE
    (DNGO1 is a group output alias name)
    but the result failed:
    failed message:
    Unexpected identifier ':=' identifier
    in flexpad
    can anyone tell me where is wrong,thank you very much!
    //===============I found the solution================
    use GOutput(groupSigName)
    Edited once, last by AndreaLu (September 20, 2018 at 8:28 AM).
    Lemster68
    301
    2,489
    Blog Articles
    7
    • September 19, 2018 at 3:48 PM
    The .trans portion of a robtarget must contain the three elements of num data type. So you must declare a num, nZvalue, then assign nZvalue:=GO1;. MoveL 0,0,nZvalue. Of course, I am shortening the Move instruction but I hope that you will still get the point.
  • Iowan
    686
    • September 19, 2018 at 4:59 PM
    I've never tried the direct entry method...
    I usually do something like:
    pTemp.trans.z:=nZvalue;
       MoveL  pTemp...
  • AndreaLu
    24
    • September 19, 2018 at 5:02 PM
    Quote from Lemster68
    Thank you Lemster! tomorrow morning ,when i go to company ,i go to try!i am try to do realtime motion control,but i dont have pc interface or egm option...so i think using GO will be a way!
  • AndreaLu
    24
    • September 19, 2018 at 5:05 PM
    Quote from Iowan
       MoveL  pTemp...
    it seems more professinalll :yesyesyes:......thank you!
  • Iowan
    686
    • September 19, 2018 at 5:14 PM
    I'm not sure if controller will let you get away with something like:
    pTemp.trans.z:=GO1;
       MoveL  pTemp...
    Edited once, last by Iowan (September 19, 2018 at 5:15 PM).
  • SAABoholic
    21
    5
    550
    • September 19, 2018 at 5:46 PM
    [/quote]
    [/quote]
    It all depends on what you're trying to achieve.
    If it's to offset pick positions in a material handling program, sure, but I'd look into using/offsetting workobjects instead.
    If it's truly to do realtime motion - then this is not a good method as you'll need to loop your move fairly fast and I think you'll end up having issues with the motion planner.
