CNT not working with PRs
  • vmec
  • September 18, 2018 at 12:49 AM
  • vmec
    7
    41
    Rj3iA controller.
    I'm new to Fanuc, although this robot is already up and running. Since day one I haven't been able to get a continuous motion using PRs. I can't use Ps since everything but three points are variable.
    Here's a snippet that is not working as intended. The controller is executing all these points as FINE.
    All points are defined and used above all of this.
    PR[1] = P[2]
    PR[1,3] = R[6]
    PR[1] R[2]mm/sec FINE
    PR[5] = P[1]
    PR[5,3]= R[6]
    PR[5] R[2]mm/sec CNT50
    PR[2] = P[3]
    PR[2,3]= R[6]
    PR[2] R[2]mm/sec FINE
    Also, I created a new program using just these lines and the points, and there's no difference whatsoever.
    I found this thread about locking PRs, of which I had no idea, but moving all the assigments above and placing the three movement instructions between LOCK PREG and UNLOCK PREG doesn't change anything. Do they need to be locked way before the program steps in those lines? Maybe putting the assignments as far as possible from the movement instructions?
    There's a similar cell with an R30iA that is using CNT PRs all over the place, working perfectly. There's no LOCK PREG and all these PRs and Rs are being updated constantly. Does it have something to do with the controller?
    Edited once, last by vmec (September 18, 2018 at 1:04 AM).
  • pdl
    272
    1,549
    • September 18, 2018 at 1:29 AM
    What kind of controller do you really have? There was an RJ3 and a RJ3iB, but no RJ3iA.
    Do you have the constant path option installed? Without that, the robot will take a different path based on speed. At 2 mm/sec, you may not see any difference if you don't have constant path.
    Why are your speeds so low?
    What's the application?
    What is the mechanical unit? (Is it a M-410 or an LR Mate?)
  • HawkME
    570
    3,270
    • September 18, 2018 at 1:30 AM
    There was a recent thread where someone was having this issue when using a register for the speed control on an older robot. I have never had this issue on a newer robot (R30iB and newer). Try changing from R[2]mm/s to a constant value.
    You can read the post here:
    https://www.robot-forum.com/robotforum/fan…9390/#msg119390
  • vmec
    7
    41
    • September 18, 2018 at 11:01 AM
    Quote from pdl
    Sorry, mistake. Rj3iB dated 2001.
    Quote from pdl
    No. R[2] is a register in which I hold a global speed for certain movements. It is 2000mm/sec in this case.
    Quote from pdl
    R-2000i 165F.
    Quote from HawkME
    Thanks for this. No luck though. I removed R[2] for 2000mm/sec, and enclosed these in between LOCK and UNLOCK. It still goes for a FINE movement.
  • vmec
    7
    41
    • September 18, 2018 at 3:13 PM
    To clarify, if I switch these PRs to Ps, continuous path works. Maybe it is just not possible in this controller?
  • pdl
    272
    1,549
    • September 18, 2018 at 3:46 PM
    Are you in step mode, or running in auto?
  • vmec
    7
    41
    • September 18, 2018 at 4:13 PM
    Robot is fully in production mode. RSR startup with UOP if it matters.
    I wish I could upload the whole program, but it's currently lacking the PCMCIA card. ???
  • pyrioun
    35
    • September 18, 2018 at 6:57 PM
    try with CNT100,
    try with P[] (not PR[])
    do you see some difference?
    if you are using register for setting speed, you can change variable $RGSPD_PREXE=1 , it's for better pre-execution.
  • vmec
    7
    41
    • September 18, 2018 at 8:25 PM
    I did test that before, with no result. CNT0 is the same as CNT100. I'm thinking Accupath or whatever it is isn't considering these PRs.
    As I said earlier, changing PR to P works. Motion gets interpolated and changing the CNT curve changes the movement, so CNT with fixed points work as expected.
    I will try setting that variable tomorrow, although it is not very safe to do that, right? Take into account I'm using registers as height offsets.
  • pyrioun
    35
    • September 18, 2018 at 11:08 PM
    could you control this variable during the program is running: $IDL_CPU_PCT (not sure this variable was available for RJ3iB)
    if the value is less than 10, cpu is very busy and could have some problem to calculate pré-execution, and if it cannot calculate pré execution CNT have no effect
    if you are using multitask , try only with one task
    Edited once, last by pyrioun (September 18, 2018 at 11:37 PM).
  • pyrioun
    35
    • September 18, 2018 at 11:33 PM
    • #11
    if you have ACCUPATH option, you can disable it (please do a backup AOA before change variable)
    to disable it:
    $CJCFG.$ENB = FALSE
    $VCCFG.$DISABLE = TRUE
    Try again your program
    to reenable it:
    $CJCFG.$ENB = FALSE
  • vmec
    7
    41
    • February 18, 2019 at 11:16 PM
    • #12
    Necroposting, but I want to post this for the record.
    Thanks for the suggestions pyrioun; unfortunately they didn't work. Most, since there were some I was too afraid of trying :icon_wink:
    They moved the robot cell and I had the time to test these. I still don't know where the problem was, but I recreated the original TP program line by line in a fresh new program, and the continuous path worked. I discovered this since a simple two point program did use interpolation so, clearly, the controller was capable of using it.
    There must be some property sheet that was permanently changed and excluded that program from using that path processor.
  • Sezwan
    • June 7, 2022 at 10:17 PM
    • #13
    Vmec, did you ever figure out what it was? I am having the same issue. Did you just copy the program with a new name or did you literally re-write each line?
