Hi pros,
I am newbie for LBR iiwa KUKA, i am making a simple project on Sunrise Workbench of KUKA, and I faced the error as in attached image. Can you please tell me the way to fix it
Thanks in advance
Hi pros,
Thanks in advance
Thank pro so much,
However, I did as so recommend, but the error still happened as in the image
And the error in Problems as in the attached image,
Since my program showed one error: cannot file slf4j, so I downloaded these files: "slf4j-api-1.7.2" and "slf4j-simple-1.7.2", then i clicked right mouse on project => properties => Java Build Path => Libraries=> Add Lass Folder (I chose 2 above folder)
[size=2]when making screenshots expand src folder and fit windows to show errors. if you click on error it should take you to a problem[/size]
[size=2]also please configure your SWB editor to show line numbers, this will make debugging and discussions much easier.[/size]
Thank you so much for your feedback,
I have already done what you suggested, I attached as in the image " Picture 1".
When I click on the error, it show that " Source not found ", I tried to attach the source as in Picture 2, but It not work. The problem here that I cannot find the source " com.kuka.roboticsAPI.applicationModel " in the "KUKA JavaLib", I do not know that i should download it or not, i tried to find some source like that on web, but i could not
Thank pros,
I have solved this problem
Since Application of Sunrise Workbench just can run in Controller, not in my PC, so it causes errors when i tried to run project directly on my PC.
I used UDP to run RobotAplication automatically by using AUTO external control
Thank pros for your help;
