This is a project bot I've inherited where someone had upgraded the software in the near past. It jogs fine and steps thru programs but doesn't work in Auto because of the fan fuse error due to missing parameter values. When trying to update the parameters to match the ones on the door, it will not open the little edit box when you select the either the decimal or binary parameter data. I know my procedure is good because I can make the changes on another DX100 just fine. I've reinitialized the controller several times, but no luck. I'm told the robot was working great before the software update. Any suggestions?
Can't modify DX100 parameters
- Skooter
A couple of questions -
What security mode are in you in?
Are you in teach or play?
Which parameter are you trying to modify? -
Which parameter are you trying to modify?Yaskawa
Teach (tried play also)
FD164, S2C789, S2C813I can change these just fine on another DX100, so I'm pretty sure my procedure is good.
Need to enter those values off the door to get past the fan fuse error.Thanks for your help!!
