ARM INTERFERENCE WITH SPECIFIED CUBIC AREA CHECK FUNCTION
  • Hello,
    I'm trying to set up ARM and Tool Interference with a specified Cube to protect a Laser Etcher we have in between 2 Ma1400 Robots Dx100 Controller.
    The plan was to set a Cube up for each Robot over the Laser Etcher
    I have been able to set up a Cube successfully for R1 and was able to set the Monitor Position to Entire. This is working great.
    The Problem occurs when I try and set up a second cube and try and set the Monitor position to Entire, as I then receive the following Error.
    ERORR 1510: Cannot edit. The maximum number of cubic interference that is able to be set to “ENTIRE” is exceeded
    The Manual I have states I have 8 cube in which I can Monitor the whole arm and tool but I'm only able to activate just the one interference cube.
    Is there something I have missed or is there a parameter I need to enable to receive all 8 cubes.
    Thanks in Advance
    Remmus
  • Hey Remmus86 ,
    I'm working with 2 Robots on a DX200 right now and I don't have the option to select the Monitoring Position. I would like to use the ''entire'' position instead of only the TCP.
    How do you get that ?
    Thanks in advance
  • Arm Interference with Specific Cubic Area Check Function software option. Contact Yaskawa.
  • The number you can define is based on the value of the parameter that Yaskawa defines.
