CAM Function Motosim
  • ravitejagali
  • August 8, 2018 at 2:26 PM
  • ravitejagali
    143
    Does any1 know how to generate robot Programm using cam function in Motosim, for metal cutting using spindel.
    Any examples would be great.
  • TSGIR
    81
    714
    • August 8, 2018 at 6:23 PM
    There are a CAM help in Motosim. you can use it. it is the best way to learn CAM function.
    It had long size and i couldn't attache to you.
  • ravitejagali
    143
    • August 8, 2018 at 6:34 PM
    With the same help manual- i started. The thing is, there are some positions where robot cant reach or and it makrs some moves over the work pieces. Why the Cam generator generates such points.. And in tooling there are something like lvule, none etc.is it something to do with it.?
  • TSGIR
    81
    714
    • August 13, 2018 at 1:49 PM
    Hello
    If you have some problem in points and robot couldn't reach to a position it is because of bad angles and orientation of robot when you are create path with CAM function.
    for solve this problem you have two way,
    1. when you are create path, go to "Torch Position" in "create path" menu. in this page you can change joint orientation and input work angle. after these setting create your path.
    2. other way is correct each point after create path. in CAM page where you can see points, go on every point that you will modify it. press "modify" and input new position for each point. you can see the black arrow on the workpiece change.
    please see attached picture for both method.
    Images
      • 30.96 kB
      • 306 × 262
      • 9
      • 19.24 kB
      • 357 × 141
      • 8
      • 24.91 kB
      • 345 × 267
      • 9
    Files
    Snap13.jpg_thumb 17.5 kB – 43 Downloads Snap14.jpg_thumb 9.46 kB – 43 Downloads Snap15.jpg_thumb 12.59 kB – 42 Downloads
  • ravitejagali
    143
    • August 13, 2018 at 2:06 PM
    Hallo.,
    Im interested, how are the results b/w realtime and simulation..? Does it works same likes external software like Spurtcam oder other CAM software program generators..?
