IRvision is inconsistent (Contrast ratio all over the place)
  • Archer
  • August 1, 2018 at 1:14 AM
  • Archer
    8
    Hi guys,
    We are running IRvision with lit tracking conveyors, and I am seeing all sorts of inconsistency with the contrast score. On the same part of the belt, I can see anything from 65% to 145%.
    The tracking conveyor uses LED backlighting.
    I cleaned the belts, but still get the same numbers, and made sure to measure on the same part of the belt each time.
    What can cause the reading to be that variable? Camera too far away? LED Flicker?
    Thanks!
  • Fabian Munoz
    133
    Articles
    1,517
    • August 1, 2018 at 12:16 PM
    Hi
    Just for curiosity, what are you using the contrast for ?
    Does it change that bad when you do CONT S+F ?
    What colour is the light , the part and the belt ?
    Retired but still helping
  • I3ooI3oo
    5
    77
    • August 1, 2018 at 2:57 PM
    Vision work can be very tricky to get right. Often we forget about the 50/60Hz flicker of most lighting. Typically we use a specific wavelength of light that will reflect nicely off of the work piece. Then using a optical filter so that only that wavelength of the light source provided will get into the camera. This will greatly reduce the possibility that the ambient lighting is adding to the light getting into the camera.
    Lastly even LEDs can flicker. Make sure the back lighting is not flickering. Most LED light sources if dim-able are actually strobe at differing rates to dim.
