Robot Cycle Power (Software/Hardware) (TP/Manually)
  • JMPLBL_NoGO
  • July 30, 2018 at 6:06 PM
  • JMPLBL_NoGO
    15
    Hey everyone,
    in the last time I found different types of cycle power options. Sometimes you can do it without touching the robot controller by select cycle power on the teach pendant (fctn-0-8). But also on different controllers I got the message that I be to switch the controller on and off.
    So my question is: when I have to restart the controller by switching off/on and when by TP? It is software version relevant or is the controller version the decisive factor?
    Gesendet von iPhone mit Tapatalk
  • Nation
    Typical Robot Error
    552
    1,933
    • July 30, 2018 at 7:17 PM
    I think it is based on controller model. R30iB Mate controllers require the user to cycle power manually, whereas normal R30iB controllers do not.
  • skalactik
    13
    111
    • August 1, 2018 at 4:43 PM
    Unless you are in control mode, then you "magically" have an option to be able to restart the controller from the TP with the R30iB Mate controller. This as bothered me in years, knowing that it is probably possible to restart the R0iB Mate controller from SW in every case ...
  • Robo_Eng_13
    26
    432
    • August 1, 2018 at 4:57 PM
    Quote from skalactik
    This is the case for many Fanuc options. The software is all there, it just needs to be activated.
  • JMPLBL_NoGO
    15
    • August 3, 2018 at 11:39 AM
    But is it possible to active the function for normal hot/cold start? Or is the option only for control mode?
