World Coordinates Error cannot move linear.
  • AML1994
  • July 29, 2018 at 12:50 PM
  • AML1994
    36
    my before post last massage net replay anyone.
    https://www.robot-forum.com/robotforum/fan…/?topicseen#new
    can't find witness marks.
    how to zero position master this robot and fix this problem.
    mastered this robot j1 face for x direction,j2 and j5 parallel the z direction, j3 parallel the x direction.
    wrist lock and jog robot mod now world coordinate is OK before the problem.but not full correct.
    wrist unlock and move the robot x direction.tool is not in y and z planes same point.offset these point move x direction.example is x direction.move any other direction.same problem
    move the robot in joint mod j2 axis.why move j2 motor and j3 motor.i think cannot move j3 motor.
    please help me.
  • robotero
    14
    346
    • July 31, 2018 at 4:49 PM
    What robot model are you working with? Post a picture
    If the marks are erased is going to be difficult to calibrate
    In the calibration posture the
    main arm (link 2) is vertical
    upper arm (link 3) is horizontal :
    at 90 degrees with link 2
    link 5 is in line with link 3
    J1,J6 are unimportant
    What is your application???
    You might no need to calibrate accurately the arm
    If you use it for pick and place joint interpolation is enough
    Welding sealing requires good calibration
    Sent from my iPhone using Tapatalk
  • AML1994
    36
    • July 31, 2018 at 6:33 PM
    my robot is """FANUC ARC MATE 100IB""".
    "robotero" i try this method.but not clear linear movement.
    x and y have small curve.but z have more curve.
    and can move this linear only wrist jog lock method.
    unlock the wrist jog tool is moving other direction.
    this robot use for welding.
    i want high accuracy calibrate this robot.
    please help me
    thank you.
    Edited once, last by AML1994 (July 31, 2018 at 6:34 PM).
  • rafahil
    143
    • August 2, 2018 at 2:14 AM
    Check the attached file
    Files
    ArcMate100iB witness marks.pdf 95.92 kB – 59 Downloads
  • AML1994
    36
    • August 2, 2018 at 3:40 AM
    thank you your pdf.
    i checked witness mark.but haven't witness mark in this robot.
    please give me another solution.
    master zero position or fixture position?
  • byrol
    13
    5
    347
    • August 2, 2018 at 7:10 AM
    Your robot's zeroing signs may have disappeared. In the "JOIN" position, the zero points of the engines do not change much. However, due to not working too much over time, some motors may deviate by 1-1.2 degrees.
    In my opinion, do not reset the reference point of your robot, but reset it with reference to the zero points you see in the "JOIN" position. We've worked on this before, we have tried many methods, but it's very hard to catch factory values at home. We are fine-tuning our source points according to the zeroing we have done.
  • ownagebyh4x
    120
    • August 3, 2018 at 2:53 PM
    I've heard but never seen FANUC zero fixture tool.
    As far as I know you could use it to get 0 position again.
  • AML1994
    36
    • August 14, 2018 at 3:38 PM
    """ robotero""" thank you.
    but not high accuracy liner movement.
    teach 2 point using wrist lock world coordinate mode.
    running robot have small curve.
    wrist unlock robot cannot move.because wrist rotate more turns.
    cannot find witness mark.(add picture below.)
    moved robot x axis.but robot move x and z axis.
    same are y,z axis.
    please help me.
    Images
      • 593.6 kB
      • 2,048 × 1,232
      • 18
      • 631.26 kB
      • 2,048 × 1,232
      • 13
      • 640.41 kB
      • 2,048 × 1,232
      • 9
      • 637.84 kB
      • 2,048 × 1,232
      • 9
      • 689.76 kB
      • 2,048 × 1,232
      • 10
      • 665.01 kB
      • 2,048 × 1,232
      • 10
      • 578.83 kB
      • 2,048 × 1,232
      • 12
    Files
    20180814_133643.jpg_thumb 29.58 kB – 103 Downloads 20180814_133530.jpg_thumb 26.33 kB – 102 Downloads 20180814_133548.jpg_thumb 26.55 kB – 99 Downloads 20180814_133552.jpg_thumb 24.55 kB – 98 Downloads 20180814_133622.jpg_thumb 26.8 kB – 98 Downloads 20180814_133715.jpg_thumb 26.29 kB – 98 Downloads 20180814_133656.jpg_thumb 25.49 kB – 97 Downloads
  • AML1994
    36
    • August 14, 2018 at 3:46 PM
    for the mastered robot.how to master this robot.
    same are y,z axis.
    how to design tool frame for this robot
    please help me.
    Images
      • 640.41 kB
      • 2,048 × 1,232
      • 10
      • 637.84 kB
      • 2,048 × 1,232
      • 9
      • 689.76 kB
      • 2,048 × 1,232
      • 12
      • 578.83 kB
      • 2,048 × 1,232
      • 12
      • 665.01 kB
      • 2,048 × 1,232
      • 12
      • 593.6 kB
      • 2,048 × 1,232
      • 12
      • 622.03 kB
      • 2,048 × 1,232
      • 10
      • 631.26 kB
      • 2,048 × 1,232
      • 11
    Files
    20180814_133552.jpg_thumb 24.55 kB – 96 Downloads 20180814_133622.jpg_thumb 26.8 kB – 98 Downloads 20180814_133643.jpg_thumb 29.58 kB – 97 Downloads 20180814_133656.jpg_thumb 25.49 kB – 97 Downloads 20180814_133715.jpg_thumb 26.29 kB – 98 Downloads 20180814_133548.jpg_thumb 26.55 kB – 95 Downloads 20180814_133530.jpg_thumb 26.33 kB – 94 Downloads 20180814_133535.jpg_thumb 26.85 kB – 93 Downloads
  • KalebM
    24
    • August 14, 2018 at 5:38 PM
    None of the bolt heads on any of my robots have paint on them.
    It looks like your robot has been painted.
    The witness marks probably need to be uncovered.
  • AML1994
    36
    • August 14, 2018 at 6:01 PM
    • #11
    how to fix non linear problem.
    robot always move small curve
  • Robo_Eng_13
    26
    432
    • August 15, 2018 at 2:48 PM
    • #12
    If you have another robot of the same model, you might be able to cheat out a zero position mastering.
    Take a mastered and functional robot that is identical, and use a miracle point or digital protractor to manually align all of the axis on the bad robot to the exact same angles as the good robot at 0, then zero master the bad robot. The only parts i am concerned about are J1 and J6, because i am not sure how you would be able to positively ID them. For J1, maybe drive to a hardstop and single axis master it to whatever the hard stop location is supposed to be? Not very accurate. For J6, if it is continuous rotation, maybe just pick an orientation, and it should be fine.
    Alternatively, Fanuc should have a method with a special fixture which they could use to re-master a robot without witness marks.
  • AML1994
    36
    • August 15, 2018 at 6:34 PM
    • #13
    ""Robo_Eng_13"" hot to do it?
    please explain.
    thanks for your anser
  • Robo_Eng_13
    26
    432
    • August 15, 2018 at 6:58 PM
    • #14
    In these instructions, Robot 1 will be your current problematic robot, and Robot 2 will be a known good robot of the exact same model as Robot 1.
    1. Take Robot 2 to its zero position.
    2. Use a miracle point or digital protractor to measure the base of Robot 2 to determine if it is level or tilted.
    2.1 If level, no action needed.
    2.2 It tilted, rotate J1 of Robot 2 so that the robot faces directly uphill or downhill (to make math easier)
    3. Repeat Step 2 for Robot 1.
    4. Determining your offset. Measure the slope of the base for Robot 1 and Robot 2. Whatever the difference is, remember that. You will be adding it (or subtracting it as appropriate) to your measurements.
    5. Use the miracle point or digital protractor to measure the angle of the lower arm of Robot 2. Add (or subtract as necessary) your angle offset, then carefully jog J2 or Robot 1 until the miracle point or digital protractor indicates you are at the desired angle.
    6. Repeat step 5 for J3.
    7. J4 should be measured to level, if your robot is aimed uphill or downhill at J1.
    8. Repeat step 5 for J5.
    9. For J6, i would assume that you are near the middle of the range. Measure across two bolts on J6 or Robot 2, then jog the faceplate so that it matches between any two bolts.
    10. Perform zero master on Robot 1.
    11. Last is to try and get J1. Move J1 of robot 1 and robot 2 to the same direction hard stop.
    12. Perform a single axis master on Robot 1 to the angle value of Robot 2.
    This is the best estimate i could come up with, if i were in a desperate place.
  • AML1994
    36
    • August 16, 2018 at 4:10 AM
    • #15
    haven't good position robot.
    how to did it?
  • Robo_Eng_13
    26
    432
    • August 16, 2018 at 1:36 PM
    • #16
    Sounds like you are out of luck. Call Fanuc. They should have a fixture to master it without scribe marks. Once it is re-mastered, add new scribe marks, so you can recover in the future. Fanuc sells the little glue on pointers that come by default, or you can just put a clear scratch in the paint across both sides. I like the arrows.
  • robotero
    14
    346
    • August 19, 2018 at 5:58 AM
    • #17
    I am sorry, I couldn´t reply early. I am busy
    If your robot has calibration errors just add move intermediate point in you weld path
    You can attempt calibrating the robot WITHOUT master fixture :
    Is possible because there are multiple solutions to reach the same position/orientation
    When the robot is correctly calibrated, the tool position/orientation will be the same when configuration is changed
    But when robot is not calibrated correctly position/orientation will be different
    Then you move the robot axis to calculate the correct angle
    Finally, use the computed value to single axis master
    Only J2, J3, J4, J5 are critical
    First, roughly calibrated/master the robot
    Tool Frame is unimportant, make it zero
    Then adjust the calibration starting from J5
    Fix a pointer reference
    Then move robot to touch the tip of the pointer
    Record the point twice (using Joint interpolation)
    Change the configuration of the second position (Flip to Non flip or viceversa)
    Move robot to second position
    If robot is not correctly calibrated, Tool tip would not return to the tip reference pointer
    Take note of the programmed J5 value
    Moving only J5 bring the Tool Tip as close as possible to the pointer
    Read the value of J5 axis
    Add both values and divide by two
    Without moving the robot single axis calibrate using the computed corrected angle
    Master robot
    That would correct J5 axis
    Try this first, then I will send instruction to correct the rest
  • AML1994
    36
    • August 20, 2018 at 7:04 PM
    • #18
    ""robotero"" cannot understand your last post.
    mastered and calibrate robot to move the witness mark.
    but my linear error not fix.
    teach same z axis and x axis different y axis 2 point.but robot running small curve.(have a small video clip.try to upload.but cannot upload for this reply)
    normally world coordinate system move the robot z direction.but robot move the x and z direction.
    that time checked xyz position value.only changing z.but WPR values are changing.
  • robotero
    14
    346
    • August 21, 2018 at 7:03 PM
    • #19
    http://www.roboticsresearch.com/01_images/03_p…rcmate100iB.pdf
    To roughly calibrate just move the robot to the posture shown in the pdf document
    Zero master the robot
    MENU -> SYSTEM -> MASTER/CALIBRATE -> ZERO POSITION MASTER
    Then in the same menu Calibrate the robot
    MASTER/CALIBRATE -> CALIBRATE
    To check that you correctly calibrate check the position values
    Press POS button
    ALL joint values should be ZERO
    Check which of your TOOL Frames is NULL (All values ZERO)
    MENU -> SETUP -> FRAMES -> OTHER -> TOOL FRAME
    Check the Tool frame definition by pressing DETAIL
    Make any NULL TOOL Frame the active TOOL
    SHIFT+COORD, then press the number of the NULL TOOL
    Then display the position in World coordinates
    The position with a NULL Tool should be
    X= 150+615+100 = 865
    Y = 0
    Z = 600 + 100 = 700
    W = 180
    P = -90
    R=0
    In this position the wrist is in singularity (J5=0)
    To jog thee robot in world coordinates, move J5 first in joint mode
    Then jog in world coordinates
    Follow the procedure to calibrate J5
    Images
      • 35.86 kB
      • 717 × 618
      • 16
    Files
    M100iB.png_thumb 14.08 kB – 89 Downloads
  • AML1994
    36
    • August 22, 2018 at 3:58 PM
    • #20
    i did this proceed-ear.
    x value is 860.
    i teach 2 point.
    same x and z point different y position.
    have same problem.move other direction small curve.add image teach point and 2 point between start and end point.
    Images
      • 1.36 MB
      • 2,048 × 1,232
      • 18
      • 1.35 MB
      • 2,048 × 1,232
      • 14
      • 1.55 MB
      • 2,048 × 1,232
      • 15
      • 1.6 MB
      • 1,232 × 2,048
      • 18
    Files
    20180822_1114290001.jpg_thumb 26.88 kB – 89 Downloads 20180822_1117180001.jpg_thumb 25.86 kB – 89 Downloads 20180822_1119520001.jpg_thumb 30.51 kB – 89 Downloads 20180822_1125250001.jpg_thumb 30.2 kB – 89 Downloads
