  4. Mitsubishi Robot Forum
trouble with my robot
  • liphe
  • July 23, 2018 at 10:01 PM
  • liphe
    18
    Hi, I have an RV-2SDB with the CR1DA-700 driver.
    When I start the robot, the errors H1091, H1092, H1093, H1094, H1095, H1096 appear. The manual shows that this error is due to the servos malfunction, but I do not know what I have to do.
    If someone has an answer or some procedure I appreciate it
  • nguyenluongdp
    • November 14, 2018 at 8:01 AM
    I have a question same. Thanks. My robot is RH-12SDH. Controller is CR2D-700
    Edited once, last by SPI2005 (November 14, 2018 at 8:16 AM).
  • dangalg
    37
    • December 10, 2019 at 9:48 AM
    me too
    Bump...
  • sean Nam
    • May 19, 2020 at 5:02 PM
    hi me too is the same problem
    if anybody knows that could you explain the reason?
  • sCZot
    55
    • May 25, 2020 at 4:15 PM
    From japan QnA mitsu page
    Q: An error occurs when the power is turned on in the SQ series. (Servo amplifier initialization communication error H109n)
    (H1091, H1092, H1093, H1094, H1095, H1096,
    H1097, H1098)
    A: In the SQ series, the startup order is fixed for the drive unit and sequencer. Turn on the drive unit first, or turn on the power at the same time.
    The robot CPU checks the status of the drive unit at initial startup. If the drive unit is not started at this time, an error will occur.
    These precautions are described in CR1QA / CR2QA / CR3Q Controller Operation Manual, "2.3.3 Power Supply Cable Connection of PLC Power Supply Unit" from controller setup and basic operation to maintenance.
  • onetwothreef
    • July 21, 2024 at 12:36 PM
    Hi, i have the same H109n error code, my controller is CR3, and doesn't come with CPU module. Would appreciate the help !
  • junior33
    • April 10, 2025 at 4:20 AM
    Tengo un problema igual con el mismo tipo de Robot y Controlador:
    RV-2SDB con el controlador CR1DA-700.
    Al iniciar el robot, aparecen los errores H1091, H1092, H1093, H1094, H1095 y H1096. El manual indica que este error se debe a un mal funcionamiento de los servos, pero no sé qué hacer.
    Si alguien tiene una respuesta o algún procedimiento, se lo agradecería.
