Hi
KRC4
V8.3.37
EthernetKRL 2.2.9
Trying to connect robot(client) to pc(server) using TCP sockets but can't get it to work.
I have checked many times the ip and ports settings on both sides and everything seams to be okay.
On PC side I'm using TCP/IP builder software that I have used many times before to connect to different devices.
DEF Sen_ConnectToServer ()
DECL EKI_STATUS RET
RET=EKI_Init("XmlSender")
RET=EKI_Open("XmlSender")
END
Rob program runs the Init line whit no errors and when trying to connect to the servers nothing happens and when time runs out error msg 14 appears.
Tried also with different port numbers but didn't work.
What port numbers do you normally use? I know it stands in the manuals but know I'm asking YOU.
Or might there be any other limitations that I have missed? Yesterday I made an application were the robot acted as server and I got it working with no problems...
-zicki
