Hello everyone,
I am working with the Kuka iiwa robot for an art project. An artist wants to control the robot using sound inputs. The kuka robot that I am using came with a ROS API that made my life so much easier.
However I have realised that this API has some limits, for example when a target frame is sent to the robot and if this frame reaches the joint limits the robot will just freeze until I manually reset it from the smartPad.
Now since it is the artist that will send the inputs and since I won't be there during the Art exhibition, I would like to bypass the API to make sure the robot won't stop in the middle of the exhibition. To do so I thought about creating an Inverse kinematics model that will compute the joint angle corresponding to the target frame, and at that point I'll make sure the robot will never reach the joint limitation, preventing it from freezing.
Anyway before, creating the mathematical model, which is quite tedious (considering this is a 7 DOF manipulator) I was researching about sunrise functions that can do this for me. I came across to this function
getInverseKinematicFromFrameAndRedundancy(frame)
but i was not able to find any documentation about it.
Does anyone know how to implement this function? What inputs does it take and what output does it produce?
Sorry for the wordy Message but I wanted to make sure everyone was on the same page. Thanks in advance!!
P.S I am open to suggestion, if you think there's an easier way to get the inverse kinematic solution
