Hello, I would like to install the newest AUTO Update (V9.10P/10 AUTO Update). I've downloaded it from FANUC but I have never done this before and for the life of me cannot figure out how to install it. Anyone ever install a new AUTO Update before?
- Dpreston
unzip it, put it on a usb stick or memory card and install
Press menu, 7 press next then install and select auto update
The controller will do an all files and an image back up then update. it will take about and hour.
You will probably have to update the vision files on your PC if you are using vision. I did the update and the vision tools are better in version 9.10 -
Hmmm, that's what I thought to do as well. When I try that I get a message that says "Auto update media or files not found".......
Make sure all of the files are at the highest level directory of the storage device, not inside a folder.
I think I found my problem. On FANUC's site, they say you can check your download by running the apverify.bat file. If it fails, you are missing a file. When I ran it, it failed. I downloaded the file again and it failed again. I guess I gotta give FANUC a call and find out whats wrong with the download....
While we're talking about it, any other new features beside the vision tools? Hope installing this is worth my while!
I had a specific issue that was addressed by the update. What version do you have now?
Currently I have V9.10P/05. I had an Auto Update fail when I tried to install an option with a PAC and FANUC told me to update my Auto Update to V9.10P/10 to see if that resolves the issue. Just after my last reply I went on to cRc to re-download the software only to find that the link for V9.10P/10 was gone. I wonder if they discovered the problem with the download and pulled it?
