The wrong moves of the axes x and y in the Cartesian coordinates
  • km427
  • July 18, 2018 at 8:23 PM
  • km427
    126
    hello
    I have a KUKA with mada : KRC2 \KR2210 _2_SSCBS\FLOOR
    I change machine data ,
    I remaster
    when i move X axis instead of moving forward, it moves to the right and left ,
    In this situation, I can not define the Tool and the appropriate Base and write the program for KUKA please help me solve my problem. :help:
    Meanwhile, teach me how to define Tool .
    Because everywhere I define the Tool of the four points, it does not end in the end and the message appears on an one plan.
    :merci: :merci:
  • panic mode
    1,297
    13,141
    • July 19, 2018 at 12:03 AM
    Are there any external axes in this system
    What is $ROBROOT
    SkyeFire
    1,061
    9,463
    • July 19, 2018 at 3:13 PM
    Jogging in which mode? World, Base, Tool?
    In Axis jog mode, does each joint move correctly?
    If you program a motion in Base 0 and execute it, instead of jogging, does it behave differently?
  • km427
    126
    • July 20, 2018 at 5:06 PM
    hi
    no ,there aren't any external axes in this system.
    Jogging in World, Base and Tool.
    if In Axis jog mode, every axis joint move correctly
    yes , I write a program after do run ,it behave differently .
    please help me.
  • panic mode
    1,297
    13,141
    • July 20, 2018 at 6:34 PM
    use correct MADA and then master robot
  • km427
    126
    • July 21, 2018 at 9:08 PM
    I change the MADA and i install new MADA and master with ETM but movement is wrong .
    Because the second-hand robot was purchased due to the wrong axis movement X and Y I think the plaque on the robot is wrong.
    How can I know, what is the main MADA on the robot?
    :help:
  • panic mode
    1,297
    13,141
    • July 21, 2018 at 9:54 PM
    robot model, serial number and matching MADA are all listed on the robot nameplate.
  • km427
    126
    • July 22, 2018 at 6:51 AM
    Where can i see the robot nameplate ?
    Except plaque. :help:
  • panic mode
    1,297
    13,141
    • July 22, 2018 at 2:39 PM
    i think we are talking about the same thing. sample is attached. location varies from model to model. in some cases this is on the base near RDC, sometimes it is on the link arm etc.
    Images
      • 48.19 kB
      • 536 × 380
      • 19
    Files
    Label Robot KR470-2 PA.jpg_thumb 32 kB – 86 Downloads
  • panic mode
    1,297
    13,141
    • July 22, 2018 at 2:46 PM
    you still did not confirm $ROBROOT value
  • km427
    126
    • July 24, 2018 at 5:04 PM
    • #11
    I install new MADA quite like plaque , but X axis move to left and Y axis move to the front, of course, moves to the left and the right ,
    So I guess the plaque has a problem
    :help: :help:
  • km427
    126
    • July 24, 2018 at 5:14 PM
    • #12
    I correctly The install Mada
    Images
      • 2.05 MB
      • 3,264 × 1,836
      • 19
    Files
    20180714_081445.jpg_thumb 26.41 kB – 85 Downloads
  • km427
    126
    • July 24, 2018 at 5:19 PM
    • #13
    :help:
    Images
      • 56.44 kB
      • 408 × 230
      • 15
    Files
    20180714_081445.jpg_thumb 26.25 kB – 86 Downloads
    SkyeFire
    1,061
    9,463
    • July 24, 2018 at 5:49 PM
    • #14
    Quote from km427
    hi
    please help me.
    Describe the program.
    To be precise: if you program a motion using Tool 0, Base 0, to move in X+, then emulate that motion (same base, same tool, Base mode) by jogging in X+, the robot moves differently between those two scenarios? Or the same?
    If programmed motion moves correctly, and jogging motion does not, this implies something incorrect in the jogging frame. But I'm not certain how that could happen.
    Are you jogging using the axis +/- keys, or the Space Mouse?
  • panic mode
    1,297
    13,141
    • July 24, 2018 at 5:56 PM
    • #15
    Quote from km427
    [size=2]I correctly The install Mada[/size]
    [size=2]no you didn't... if you did, this would likely be ok. [/size]
    [size=2]based on my observations:[/size]
    [size=2]you fail to communicate details of exact setup including robot mounting.[/size]
    [size=2]you fail to report $ROBROOT value[/size]
    [size=2]you fail to communicate DETAILS of the directions ("left and right" is not clear which side is positive)etc.[/size]
    [size=2]clearly you cannot or don't want to answer questions and since there is no way of communicating with you, my recommendation is to hire someone to sort this out.[/size]
    [size=2]
    :beerchug: [/size]
    Edited once, last by panic mode (July 24, 2018 at 6:01 PM).
  • km427
    126
    • July 24, 2018 at 8:43 PM
    • #16
    I am jogging using the axis +/- keys.
    I install KRC V5.4.14 , Mada KRC2\KR2210_2_SSCBS\FLOOR
    I use Robot for pickup glass ,so important the KUKA the correct movement is in the direction of the Cartesian system .
    :merci: please help me .
  • panic mode
    1,297
    13,141
    • July 24, 2018 at 9:07 PM
    • #17
    Quote from km427
    i rest my case... :icon_frown:
  • hermann
    412
    2,628
    • July 25, 2018 at 6:23 AM
    • #18
    You still did not check, report the value of $robroot.
  • km427
    126
    • July 25, 2018 at 2:17 PM
    • #19
    What do i check?
    Amount of axis positions when moving robot?
  • panic mode
    1,297
    13,141
    • July 25, 2018 at 5:54 PM
    • #20
    1. $ROBROOT is a system variable. variables have values. what is the value of this variable?
    2. how EXACTLY is the robot mounted?
    3. do you know about Cartesian coordinate systems? There are many but in this case you should stick with WORLD. Do you know where WORLD is and how is it oriented?
    4. no robot axes positions (joint positions) do not matter here.
    5. why don't you read and use search?
Users Viewing This Thread
  • 1 Guest
