VisionTech settings - save button not available
  • Hi any help welcome,
    I am setting up a KukaVision evaluation camera. The Sensor is connected etc and I can see it in VisionTech.
    I am using the emergency activations.
    I am unable to save settings in VisionTech/Settings page. The Save button is not available / not active.
    The Settings such as Result interrupt, Wait flag result, Result flag, No Success flag, EKI alive flag, I cannot save values for.
    So this step I am unable to setup, without being able to press save button.
    :help:
  • 1 what version of software?
    2 where exactly you try to make settings? WoV or smartPad?
    3 if smartPad, are you logged in as Expert?
    4 did you check VT manual?
  • Hi Panic Mode, thanks for getting back to me.
    I got this resolved since I posted.
    I had to re install Kuka Vision tech onto the smartpad and everything worked as it should.
