Hey y'all!
In the System Variables manual it says that I can change my editor to show my running sps file rather than my standard cell file by using
However, when I tried to do so, I got error 1388 "$INTERPRETER variable write-protected in module SPS, line 591." Line 591 is blank but I assume it meant line 593, which is exactly the code above. I thought this might be because I did not have a regular src file selected at the same time (as the manual says you can only change the interpreter if you have both selected (does anyone know how to get around this?)), but even when I select an src file and then run my sps I get the same error. Any thoughts?
Thanks!
