Recently we had Fronius and Motoman come into the plant I work at to integrate their welders to a cell we have. The motoman tech that was here deleted the houskeeping job that we had and we had to put a backup in. Since then we have not been able to call the master job from the quick keys in the job menu. When I go to Job, Control Master, and select Master Job it only gives me the option to call the master job, not to set the master job. If I select to call the master job then an ERROR 2290 on the pendant stating that the master job is not specified. This is a DX200 that I am working on. Thank you in advance for any help.
Need to set master job
CozyCroobie -
July 10, 2018 at 9:46 PM -
In at least Management security level, go to SETUP, go to FUNCTION ENABLE. The top line should say MASTER JOB CHANGE. Change this to PERMIT. I assume the obvious has been checked such as in teach mode.
