Hello
When I tried to master and calibrate the robot i got errormessage 13007 and faultlamp,heldlamp and notcalibratedlamp lights. Then i got errormessages 3038 =Mastering not done.
Greatful for all help I can get.
Tommy
Fanuc-420f. Masteringproblem
- TommyMagnus
which controller?
Generally, try jogging the robot a couple of degrees in + and - in each axis before moving it to zero position, then try to master and calibrate again.
Hello
Thanks for your reply.
Im not so familiar whith the system. Where can i check the controlertype? -
look for a sticker which says FANUC System (something), for example FANUC System R-H, or R-J2.
Hello
I found FANUC SYSTEM R-MODEL H
