Hello all,
I am wondering if there is a command to erase a weld path that i have saved to a file?? i do multipass welds on every weldment i have, i seamtrack the corepass and then i path replay the 2nd 3rd 4th 5th and 6th pass with offsets. but sometimes i have to save path to a file and go back to that weld later on in the program. the problem im having is that the robot only saves that file once so when i run the program again on any weldment i do after that it will not overwrite the path. and will just use the path that was used the very first time it was saved. i have been able to get around it by erasing these paths manually before the start of each routine, but is there a simpler way of doing this by adding a command in the program??
Thanks,
Beau @ SureFab
