Hi there,
I have a shared folder on the KRC where we place programs from the office server. From this folder we copy paste to the Program folder to get them compiled. Suddenly, the copy/past procedure freezes while the KCP shows the "inserting file". A Cancel button appears at the bottom of the main window (where you get all the contextual menus options normally) but nothing else happens. Selecting the cancel button does nothing. Also browsing to other folder doesn't work and everything like going to configure, monitor or other menus gets super slow. I did several cold reboot but without any success.
Do you have any suggestion to fix this?
Best,
Marco
KRC stacking when copyng program to folder program
Marco -
June 27, 2018 at 8:18 PM -
Thread is Resolved
Are you trying to copy&paste multiple files at once, or have you tried doing one file at a time?
Have you tried cancelling the SPS first? Is the file you are replacing linked?
Have you confirmed that the files you're trying to paste are correct? Sometimes, bad header data or formatting can cause this kind of issue.
How large is this file(s), and how much RAM do you have remaining available in the controller? I've seen this kind of thing happen when I got close to the RAM limit.
thanks. Programs were fine, file size small, memory with enough space. I tested with SPS selected and cancelled. Still nothing. I copy/pasted other files (only one, multiple ones), it worked. Then, I regenerated the programs from Sprutcam, placed them in a different folder and copy/pasted again. It worked. So at least I know how to fix this kind of issue although I ignore what caused it.
