Recovering from a shock sensor alarm in PLAY mode
  • ashwinmudigonda
  • June 27, 2018 at 7:16 PM
  • ashwinmudigonda
    43
    I have an MH12 robot on a FS100 controller. I am trying to use a gripper to pick parts and would like to use the shock setting as a sensor to help me stop an IMOV motion.
    I have configured the shock sensitivity settings and call it with the SHCKSET command in the job. This is working as expected. My question is how do I capture the
    ALARM 4315
    COLLISION DETECT
    alarm and set a bit so that I can use it with an IMOV.
  • 95devils
    235
    8
    1,951
    • June 27, 2018 at 10:19 PM
    Ouch. Oh, what fun. Rough idea here. In the ladder write a rung with at least NO contacts with the address of the Specific Output for PLAY (50054) and for a minor alarm, I believe 50011. Have that go to a WXOR. Use a source of a constant of 4315 and a source of a register (I believe M640) that is the alarm number, the destination is then an unused M-register. If Alarm 4315 occurs the destination M-register should be 0.
    You could then duplicate this rung but use an ADD instead of a WXOR. Add a constant value, like 1, 2, 4,8,... to the M-register.
    You then could move the value of the M-register into a Relay(Byte) for an address of the universal inputs. I hate to waste an additional 7 inputs for this. But it is a way.
    Somewhere you would want unseal the input. I would probably use an output for that.
    Works in my head. Hopefully, it gets you close enough that you can massage to your liking.
    Edited once, last by 95devils (June 27, 2018 at 10:55 PM).
