Communicate 2 robots by ethernet
  • seurjomo
  • June 18, 2018 at 2:12 PM
  • seurjomo
    Hi!!
    Is possible communicate 2 robots Fanuc between them? I want send signals between them, the station has PLC and the robots are communicate by ethernet. But i want know if is possible send Local IO's, between them.
    Thanks.
  • stare284
    25
    373
    • June 18, 2018 at 2:35 PM
    If you have controllers with 2 Ethernet ports then you can pass signals through the open port to each robot and by pass the PLC.
    Or you can just pass them along through the PLC.
  • Fabian Munoz
    134
    Articles
    1,517
    • June 18, 2018 at 4:20 PM
    seurjomo
    I think your are referIring to I/O that you can wire, right ? A truly physical I/o
    Unless you have Honda connectors or Fanuc I/o modules (they look like a PLC) , you dont have anything, except (if you want to do a lot of wiring), you can use the EE connectors and put an umbilical cord in between.
    Retired but still helping
  • rafahil
    7
    143
    • June 21, 2018 at 1:17 AM
    Yes, it is possible.
    You can create a robot ring to communicate the two robots, using RIPE.
    You can communicate up to 16 robots using RIPE
  • andreic
    25
    282
    • June 22, 2018 at 12:43 PM
    It's not clear for me what kind of I/O's you want to send, but if you have EGD I/O you can configure the robots to send I/O between them by Ethernet.
  • malain
    14
    63
    • November 29, 2019 at 9:21 PM
    Hi Rafahil,
    How do you write in a numeric register of a other robot by using RIPE? So let say Robot_A need to write (or read) the numeric register of the robot_B? I think i,m ok to setup the RIPE... but after that how send the data?
  • vipinpunneri
    137
    • December 1, 2019 at 10:23 AM
    I think this what you need
    Thanks regards<br />Vipin..
  • Fernando303
    • May 21, 2021 at 6:56 PM
    Could you share me the document vipinpunneri ? Please
    SkyeFire
    1,061
    9,463
    • May 22, 2021 at 7:34 PM
    That's not a document -- read the text in the image. It's a brochure for J740, "Data Transfer Between Robots," which is a particular option package that must be purchased from Fanuc and installed on each robot. It probably also requires the KAREL option, and may have other dependencies.
    You would need to contact your Fanuc service representative and provide your robot F-numbers to get a quote.
  • Fernando303
    • May 31, 2021 at 5:20 PM
    I so sorry my friend, thank you for advice. I will contac my fanuc service representative as soon as possible.
    Regards.
  • Roboticien12
    15
    • June 1, 2021 at 2:37 PM
    • #11
    Yes it's possible, but any way you need to contact fanuc because you need to add an option to your robot ( I did that for two robots shars the same encoder )
