print a message?
  • AiSard
  • June 18, 2018 at 1:20 PM
  • AiSard
    44
    Been bugging me for a while but can never quite figure out how to word the search criteria for this,
    But is there a command to print text and/or variables, perhaps in the error log portion of the pad, during the running of the robot?
    something similar to a print to console, println(), etc?
    thanks,
  • panic mode
    1,297
    13,141
    • June 18, 2018 at 2:16 PM
    https://www.robot-forum.com/robotforum/kuk…rum/read-first/
    Edited once, last by SkyeFire (June 18, 2018 at 3:44 PM).
  • AiSard
    44
    • June 19, 2018 at 7:04 AM
    KR C4 compact
    KSS 8.3.25
  • panic mode
    1,297
    13,141
    • June 19, 2018 at 1:35 PM
    there is a function called Set_KrlMsg()
    it can display up to three values.
    if you are ok with displaying just one, lookup MsgLib
    if you need more than three, check SWRITE
  • raulboter
    17
    • June 20, 2018 at 5:01 AM
    You will have to change some stuff at the sps file and at the config.dat.
    He res a template you may use in both of them:
    First of all declare those parameters at config.dat
    DECL KRLMSG_T mymessage
    DECL KRLMSGPAR_T Parameter[3]
    DECL KRLMSGOPT_T Option
    INT handle
    BOOL msg_one=TRUE
    BOOL MSG_PRE=TRUE
    BOOL msg_show=TRUE
    Then those at SPS
    INI
    msg_one=false
    msg_show=false
    USER PLC
                  	;FOLD
    IF NOT msg_one THEN
    mymessage={modul[] "Here's the top of the message", Nr 1000, msg_txt[] " here is its content"}
    msg_one=TRUE
    handle = Set_KrlMsg(#NOTIFY, mymessage, Parameter[ ], Option)
    ENDIF
    ;ENDFOLD
                  	;FOLD
    IF (here you will define when your message will appear) THEN
    mymessage={modul[] "here's the top", Nr 1001, msg_txt[] "here's the content"}
    msg_show=TRUE
    ENDIF
    ;ENDFOLD
    That's for KRC4, if your controller is a KRC2 then it's a bit different
    Edited once, last by raulboter (June 20, 2018 at 5:03 AM).
  • AiSard
    44
    • June 20, 2018 at 9:06 AM
    After looking in to this a bit more, mine eyes have been opened :icon_eek:
    Didn't know about the Programming Messages documentation before, though will probably be fine with MsgLib
    Thanks guys
