We have the error 20042 , in manual says : 20042: Motor 7-x overload .
what motor is referring ? how can we resolve this error?
I think the error 20041 is refer to 6 motor of robot but the error 20042
Look through the event messages for other errors, often times there are more than one, but only the last one is displayed. The others could tell you which axis.
No , theres no error.
Only that error then another one with chain ENABLE open
And than Emergency stop.
is there any PTC conexion? Wheres they are conected?
In manual is write there need to be 4 fuse , F1 , F2 , F3 , F4 and we only see F1 y F2.
Did you find solution? I have same error
EDIT: Find a solution. You need to short EXT PTC and EXT PTC 0V signal for external axis to solve this.
Dear sirs,
I have a problem with my robot ABB IRB1400 M94A S4.
Report error 20042: Motor 7-x overload. Did you solve your problem? I'm asking for help. Do you know what I need to do to remove this error? Thanks in advance. Wait for response.
Best regards
Iliyan
