I am beginner to robot welding I need to know effects of weaving parameters on weld
Weaving parameters
- Somu mech
what do you mean?do you mean what will weaving do for and to a weld or do you mean if you change settings in the weave file how it affects the weave?
for a single weave, use the following:
Amplitude is the half-distance of the width of the weave. If you want a 5mm weave, put in 2.5 mm
Frequency is the amount of cycles/second of the weave. Generally most people weave between 2.5 and 4HZ
Angle is the angle of the torch, most commonly 45 degrees for a fillet weld in flat, horizontal position.For a wider weave, increase the amplitude.
Adding weave adds cycle time
