Someone can explain which are de difference between DX100 and DX200 controller?
DX100 vs. DX200
Diego -
May 29, 2018 at 4:55 PM -
Idont know if it's the complete list. But here are some.
That attached list is YRC1000, not DX200. DX200 does not have the VMAX option, and I/O is still under UNIVERSAL OUTPUT and UNIVERSAL INPUT, not GENERAL INPUT and GENERAL OUTPUT
Here's my observed list of differences between DX200 and DX100
- DX100 pendant is white, DX200 pendant is grey
- security codes are maximum of 16 characters on DX200, whereas DX100 is 8 characters
- enhanced FSU option on DX200 with 32 ranges as well as inside/outside monitoring
- you can comment out and edit lock individual commands
- IF-THEN-ELSEIF-ELSE and WHILE-ENDWHILE has 14 options on DX200 for AND/OR, as opposed to 3 for DX100There are probably a couple of other options that have changed, but that's a summary of the things I see.
Yes, you are right. But now he knows whats new in YRC1000
That attached list is YRC1000, not DX200. DX200 does not have the VMAX option, and I/O is still under UNIVERSAL OUTPUT and UNIVERSAL INPUT, not GENERAL INPUT and GENERAL OUTPUTHere's my observed list of differences between DX200 and DX100
Ok, thank you very much for your help.
Nothing about how many axis can it drive, really? I have to retrofit an Arcworld cell, adding one more possitioner to an existing cell with two robots.
And I'm not sure if the controllers could drive tottaly 6 axis for the possitioners (3 axis for each one). -
May I ask where to get that document about the YRC1000?
I want to make our calibration software, which already supports Yaskawa controllers up to DX200, work with the YRC1000 as well and this doc seems to be a perfect starting point. Can somebody please provide a digital copy, or at least a title/part-number?
Thanks!
And I'm not sure if the controllers could drive tottaly 6 axis for the possitioners (3 axis for each one).The DX200 can support up to 8 robots, 8 base tracks, and 24 external axes. Not to exceed 72 axes total.
