Rotate the A6 axi every 2 degrees until it reach the 360.
  • Hi
    Its possible to rotate the 6 axis in incremental way.
    I need to rotate every 2 degrees until it reach the 360.
    How can i do it ?
    I already made a project by offset, but its (X, Y , Z) in angle i search the documentation i cant solve it.
    My robot is a kuka KRC2. i have a similar program in Abb. but is Kuka I don't know
    in Abb is like that
    in abb program is like this :
    VAR jointtarget jpos10;
    VAR num nAxis6Pos;
    WHILE nAxis6Pos < 360 DO
    jpos10:=CJointT();
    jpos10.robax.rax_6:=jpos10.robax.rax_6 + 2;
    nAxis6Pos:=jpos10.robax.rax_6;
    MoveAbsJ jpos10, v100,fine,tool0;
    ENDWHILE
  • [size=2]Axis 6...?[/size]
    DECL AXIS Joints
    Joints = $AXIS_ACT
    WHILE $AXIS_ACT.A6<360
        Joints.A6 = Joints.A6 + 2.0
        PTP  Joints
    ENDWHILE
  • [size=2]but....[/size]
    [size=2]what is the point in moving step by step? why not go to target position in one move?[/size]
    [size=2]also y default A6 is configured as "rotary" axis. this means that soft limit s are +/-358deg. [/size]
    [size=2]to move past those limits, axis type would need to change to "endless"...[/size]
  • the objective
    I have the robot connect to a stamping press, and the robot holds a piece , and i need to rotate 2 degress and then the stamping press makes a hole, and repeat this until a full cyclye 360 degrees.
    the piece have (360 / 2 ) = 180 holes .
    I will test today your code.
  • KRC1 is not a robot. It is a robot controller. Language is the same. To run program it must be selected. Only programs that compile without error can be selected....
  • the problem when I copy the program, the part "Joints.A6 + 2.0" gives error and don't compile. I think its missing some part.
    can you help me with a simple program ?
    DECL AXIS Joints
    Joints = $AXIS_ACT
    PTP Joints
    ENDWHILE
  • [size=2]that is a sample program and it compiles and runs fine for me.[/size]
    [size=2]if you get errors but you want to keep them to yourself, why bother with forum? [/size]
    [size=2]feel free to resolve them on your own. [/size] :uglyhammer2:
  • I have experienced in abb robots, but in kuka I’m starting know.
    I post 2 photos of the errors with the sample program.
    Maybe I’m make a newbie error, but as I said im starting in kuka.
    Looking at the photos, it’s normal ?
