During the save routine I get errors that report error reading file but when I check the upload status it is uploading that file. Is this an update issue between the computer and the controller?
I am uploading from RJ2 through a 25 pin to 9 pin into an old windows xp laptop.
This doesn't seem to effect anything, just an annoyance.
Thank you.
KFloppy
mortoch -
May 24, 2018 at 7:51 PM -
Is it always the same file? Are other files saving? In the past I had a problem saving a TP file on an R-J2. I copied the file with a different name and was able to save it. I deleted the problem file and renamed the copy to match the original and everything worked after that. Not sure why.
I sometime get random error with the serial communication, in the end everything work but those error dont seem to have any impact on the file transfer.
Might just be some kind of noise on the comm line???
I would say it always the same fileS as it is more than one. To me it acts like a delay that the kfloppy sees and doesn't like because it pops up and then the file starts it save. This is more of a curiosity because the files work.
