Hello, friends! I bought a used robot and ran into some problems. I can not start automatic mode. Old programs that came from the previous owner also do not run. In manual mode, the robot moves. Maybe this is due to a lack of security that is not available at the moment? And how do I access an engineer? How do I reset my settings?
Robot hunday hs 165 error E1457
- Dmitry_Mid
You can contact the manufacturer or former owner of the robot
Hello, friends! I bought a used robot and ran into some problems. I can not start automatic mode. Old programs that came from the previous owner also do not run. In manual mode, the robot moves. Maybe this is due to a lack of security that is not available at the moment? And how do I access an engineer? How do I reset my settings?Hello
E1457 - this error about external stop signal inputted (Service/Monitoring/Input-Output Signal/Private Signal Input)
here is status of Emergency Stop (Ext) if it's have on status your should check I/O board (positive or negative logic can be applyed)
