Advertising
how to know robot configuration from robot axes
  • Hi all,
    I need to know how to get de robot configuration (RST) when i have all the robot axis (j1=-160/j2=52/j3=0/j4=-36/j5=-118.5/j6=-56 for example).
    is it possible to make a macro in excel?
    thank you so much
  • sure... you need to have DH parameters for the robot (from robot geometry) and then use series of calculations (one for each joint) using homogeneous transform. Kuka uses Rz(A)*Ry(B)*Rx(C) as transform convention.
    Do you know where can i find the formula needed to do it? (convert robot joints (j1,j2,j3,j4,j5,j6) to robot configuration)
    I know the robot tcp (x,y,z,rx,ry,rz), locations (x,y,z,rx,ry,rz) and work frame. they are all welding robots
    EDIT: i already have robot joints
    Or you could call the built-in FORWARD function on your robot controller.
    Fubini
    Thanks, but we have to configurate 79 robots with several trayectories each, we need to do it offline, do u know another way to do it offline with the data i have written before?.
  • If you have the axis angles for the robot joints, S&T should be nearly trivial to determine. If all you have is Cartesian coordinates, you will pretty much have to do the full DH kinematic model -- I ended up running into this exact problem about a year ago.
    S&T are both Integer variables, representing a binary pattern where each bit reflects the position of a given axis. The Least Significant Bit (Bit 0) is always A1, and Bit 5 is always A6.
    The T values simply indicate if an axis is above or below 0. The T bit is False if the associated axis is >=0, and True if the associated axis is <0. So for example, if $AXIS_ACT={91,-45,37,1,-1,0}, the T value would be 'b010010', which works out to an integer Base-10 value of 18.
    S disambiguates axis positions when a given Cartesian position can be reached with multiple different axis configurations. S only has 3 bits. Bit 0 indicates if the robot is working in the Basic Area (False) or Overhead Area (True). Bit 1 indicates if A3 is higher or lower than Phi, but Phi is dependent on particular robot models. Bit 2 indicates A5, and is False if ((($AXIS_ACT.A5 >=0) AND ($AXIS_ACT.A5 < 180)) OR ($AXIS_ACT.A5 < -180)), and True if (($AXIS_ACT.A5 >=-180) AND ($AXIS_ACT.A5 < 0)) OR ($AXIS_ACT.A5 >= 180)).
    The granular details are explained in the KUKA manual -- search for "status and turn".
    One thing I notice that doesn't appear to be documented is where one might find the value of Phi in the MADA for a particular robot.
  • Thanks, i´m going to try this.
    Regards
