Hello friends,
I have a backup of KUKA Robot. I want to see iosys.ini files to check the io configuration of the robot. I saw all the folders but I can't find any INIT folder in the backup. While I searched through the path C > KRC > Roboter, I found Config, Rdc and Template folders. How I can find INIT folder or how I can see iosys.ini file ?
INIT Files in KUKA Robot backup
- Ninad Joshi
Well I have init folder under location backup> KRC\ROBOTER and inside init is iosis.
May be the folder is hidden in your computer? try searching the init folder in serach box(under search this pc) instead of going to that path and look if there is hidden folder https://www.howtogeek.com/howt…folders-in-windows-vista/
https://support.microsoft.com/…windows-show-hidden-files -
I will check. Thanks for your involvement.
Is this a KRC1 or KRC2? If so, then IOSYS.INI should be in the Archive, unless someone tampered with the backup settings. KRC4s, however, do not use IOSYS.INI anymore.
Hello SkyeFire, thanks for the involvement. Really sorry for the late reply, but this is a KRC4 controller. As you said, if KRC4 do not use IOSYS.INI file then how should I see IO configuration and IO mapping of the robot on my laptop?
Open your project file in Workvisual.
Fubini
Thank you Fubini. I will check.
please, where do you find the necessary data? Thank you. -
