hello guyz. I am new robot programming. I am sorry to ask some weird question I hope I can found help. I have a project that I will program palletizing robot. so, I am using KRC 4. there are some problems in code maybe need someting. when the robot goes home position to start position and see sensor is true, then it is going to pick place.
-but when it is going there,if sensor become again false, the robot is stopped.
-after it puts the piece,it goes again the same start place. I want it to go -50 z direction. (it should remembers to pick point and goes to next one)
-the same problem is in the put place. it goes to same point to put.
so,what should I do? The problem is in code or what? plz help me guyz.
DEF prog( )
INI
;definiton interrupts
INTERRUPT DECL 10 WHEN $IN[01]==FALSE DO piece_control()
INTERRUPT DECL 11 WHEN $IN[01]==TRUE DO piece_found()
PTP HOME Vel= 100 % DEFAULT
$ADVANCE=3
;come search start point (ssp=start search point)
PTP Pssp Vel= 100 % PDAT1 Tool[1]:kbs Base[0]
;if sensor false go search_path
;search start point to end point
IF $IN[1]==FALSE THEN
INTERRUPT ON 11
search_path()
;;INTERRUPT OFF 11
$ADVANCE=3
ENDIF
;when sensor true, pick and put then come back
IF $IN[1]==TRUE THEN
INTERRUPT ON 10
service()
$ADVANCE=3
INTERRUPT OFF 10
ENDIF
END
DEF service()
INI
$ADVANCE=0
PTP Pssp Vel=100 % PDAT11 Tool[1]:zeytool Base[0] ;search start point'e gidis
PTP Pg Vel=100 % PDAT11 Tool[1]:zeytool Base[0] ; Pg noktasyna parçayi birakmaya gider
PTP Pb Vel=100 % PDAT11 Tool[1]:zeytool Base[0] ; Pb noktasyna parçayi birakmaya iner.
END
DEF piece_control()
INTERRUPT OFF 10
BRAKE
RESUME
END
DEF piece_found()
INTERRUPT OFF 11
BRAKE
RESUME
END
DEF search_path ( )
INI
; go start to end search point until input true
LIN Pesp Vel= 0.2 m/s CPDAT2 Tool[1]:kbs Base[0] ;esp=end search positon
WAIT FOR TRUE ;it is the new added
$ADVANCE=0;when I add it, the program doesnt work.
END
