Hello everyone,
Is it somehow possible to number motion points using registers? On Kuka robots I've done this using a trigger and when the motion point was reached, a step counter was then updated. I can easily say R[1]=1 after the point but I'm worried with the robot reading 3 lines ahead that the registers will have the wrong values for shorter motions.
I need to create a program that returns the robot to Home position regardless of where the robot is. To do this I need to number each point so that the robot knows where it is and will either go forwards or backwards in the program, depending on gripper status, to Home position. I need to find a way to do this so that the register numbers only update when the position coordinated have been reached and motions should be continuous.
Any ideas on how to do this?
